enter name of drawing to open??
This widget could not be displayed.
after a recent crash civil 3d now asks me to type in the full path and file name for a file i want to open after selecting the open option on the menu or toolbar.
i know there is a variable that requires re setting but i don't know how. advice gratefully recieved.
thanks!
Replies (38)
Syed_aligoher
Observer
Observer
when you open the Auto CAD then you wright fiedia enter then press 1 ok
lutf80
Community Visitor
Community Visitor
Thanks a lot i have the same problem since half a month very helpful
In C3d 2018. I'm getting this same prompt. I'm typing in "FILEDIA" and it says "cannot find specified drawing.." What should I do?
^^ thanks for the help reading this post helped fix the problem!
Now I can tell there are more people saying the same as I do. I heard there are other softwares with more commom sense in their programing than this one. For Autodesk: K. I. S. S. (Keep It Simple Stupid).
Thank you for your big help!
filedia 1 really works! tnx for that new knowledge.
Typing in this option also works for the original AutoCAD program, not just AutoCAD Civil
@Anonymouswrote:
FILEDIA=1
neilyj666
@Anonymouswrote:
FILEDIA=1
Yes it does as Civil is built on AutoCAD.....in fact pretty much all the original AutoCAD commands work in Civil...!!!!!
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2025 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Thanks a lot
RunarPJCMNN
Observer
Observer
Worked perfectly, been trying to fix this stupid issue for ages!
after i get : No system variable changed **** . what can i do abour it ?
It has been a while since I had this problem and posted this question so I do not recall for sure.
for your question have you typed in sysvarmonitor (for system variable monitor) on the command line?
when I do this I get the System Variable Monitor box where I can change the variables or reset them all.
I believe I have reset them all before when I was having that problem  and it resolved the issue.
If the problem you are having is that you can not open a drawing using the 'open drawing' icon and it is wanting you to type the name of the drawing to open in the command line I think I fixed this issue before by opening the system variable monitor box and changing the FILEDIA variable to 1.  I think you can do this directly on the command line also by typing filedia and entering 1.
hope this is helpful.
çok teşekkürler kral
Greatly appreciate that!!! Mark. that was very help full
anita.michaud18
Community Visitor
Community Visitor
NONE OF THOSE SOLUTIONS ARE WORKING FOR ME.  WHEN I TYPE ON THE COMMAND LINE IT GOES UP ONTO THE BAR THAT SHOWS UP ASKING FOR THE FILE NAME,  I SEEM TO BE STUCK
anita.michaud18
Community Visitor
Community Visitor
ME TOO
terry2
Community Visitor
Community Visitor
When I attempt to open a drawing session, after I select  open I get a notice in a white box That says "entEr name of drawing" and my screen freezes and will not respond
