Any reason why I am getting the circles around the stars on my seal block when I do not have them in the block itself? It seems to be attached to the block when I import a layout from the template file. I use the regen command to minimize the circles but they do not completely go away.
Solved by pendean. Go to Solution.
Since it is a system variable, is there a way to make certain points appear with a different geometric representation on plans? Something in point styles I assume?
PTYPE allows you to alter the appearance of the points, but it affects all points globally, you can't have different points with different display types. There is one type that displays as an invisible dot, that's probably the one you want.
That setting is for native acad points not civil3d cogo points
Joe Bouza
