Engineer's Seal Block
LarryS23
LarryS23
Any reason why I am getting the circles around the stars on my seal block when I do not have them in the block itself? It seems to be attached to the block when I import a layout from the template file. I use the regen command to minimize the circles but they do not completely go away.engineers seal.JPG
Replies (7)
pendean
Community Legend
Community Legend
PDMODE variable, change the setting: look up usage in HELP. Those are point objects in your artwork.
LarryS23
Thank you!
LarryS23
Since it is a system variable, is there a way to make certain points appear with a different geometric representation on plans? Something in point styles I assume?
jeff_rivers
PTYPE allows you to alter the appearance of the points, but it affects all points globally, you can't have different points with different display types.  There is one type that displays as an invisible dot, that's probably the one you want.
Jeffrey Rivers
Win 10 Pro 64-bit, Intel i9 3.7GHz, 64 GB
NVIDIA RTX A4000
C3D 2020 V13.2.89.0
cwr-pae
Points on defpoints layer are not affected by PTYPE.
cwr-pae
Now that the block is created you no longer need the points. Why not just delete them?
Joe-Bouza
That setting is for native acad points not civil3d cogo points
Joe Bouza
