Civil 3D Forum
Empty section views.
5 REPLIES 5
286 Views, 5 Replies
Hello Forum,
Am kindly requesting for assistance on how i can have my road section reflected in my section views,...i created the suface, Alignment, Profiles, Assembly,corridor & corridor surface, samplines & then section views. But after they are formed, they reflect nothing as attached in the screen shot below....i would like to have my road assebmly reflected in the section views,.....i will be very grateful for any kind of help/advice offered.
Bravo!
5 REPLIES 5
Udo_Huebner
Instead of a screenshot, better upload your drawing right away. Then we can check your drawing and point you to the needed settings. I suspect missing data sources for the same line groups.
Gruß Udo Hübner (CAD-Huebner)
Jeew-m
Check your section view minimum and maximum elevations.
Sometimes they may be out of the region where your corridor is.
There is a lisp to resolve this issue inside a thread in Civil 3D.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
in reply to: Udo_Huebner
Attached is my drawing sir,
Am grateful for your reply.
wfberry
Your section elevations are incorrect.  IOW, the actual sections are mostly above your sections.
Your section view properties are USER SPECIFIED and perhaps should be AUTOMATIC.
You may want to also add "Corridor" to you sample lines.
Bill
Jeew-m
you have the solution here in this LINK.
Jeewana Meegahage
Design Engineer
Rail Community
