Hey Folks,
Here's another odd one I need help on. I'm trying to setup my cross sections to be like FDOT standard, and to that end the sections have to essentially stack on top of each other. So, here's my problem: I display the elevations on the left side of the grid and the top elevation of the bottom section overlays with the first elevation of the top section. Is there some way to get the first elevation to NOT appear?
I've attached a picture showing a close up of the overlap problem. Thanks for any help you can offer
Hey Folks,
Solved by BrianHailey. Go to Solution.
I haven't tried this but perhaps have shorten the height of the section view by a hair. Instead of having it 20' tall, have it 19.9999' tall. That may prevent the top elevation from displaying.
On a side note, have you looked at how Florida has their section views set up in their STATE KIT?
Thanks, it worked. Not exactly as I wanted as I would prefer the top elevation to remain and get rid of the one at the bottom, but it's close enough. And yes, I installed the FDOT version - it's not set up to display it properly. Go figure!
