Edit Structure names
Muthya
Message 1 of 16
Muthya
I intend to edit the all Structure Names in the Vista. I have the correct names arranged in the same order in an Excel
file. It is only allowing me to do it one at a time. Is there some way I can achieve this for all structures in one go?
And, if I edit the Structure namesin the Structure list, will the pipes list automatically reflect the changes?
Thanks.
Replies (15)
Message 2 of 16
Joe-Bouza
you have a couple of ways
The modify tab>> pipe networks>>design >> rename renumber allows you to select the order in plan or panorama and apply a new name template.
I prefer the panorama selection it easy especially if the order is related to an alignment
Joe Bouza
Message 3 of 16
Muthya
Wow! That was a quick answer. Thanks.😊
I too would like to do it in Panorama. I would love if it were possible like in a Spread sheet such as in Excel. Is it possible? Is there some trick?
Message 4 of 16
Joe-Bouza
importing from Excel may be possible but I dont know how.
what issue are you having with the panorama / naming template method?
Joe Bouza
Message 5 of 16
Muthya
I have created a network copying from 2D Shop drawings provided to me. I created the parts. The network has structures, which currently has some place holder names generated by default. I now want them renamed to suit their proper names copying from 2D shop drawings. Since it was produced in a haphazard manner, the place holder structure names, generated by default, are not in order. I thought, I could use the Excel routine to edit all structure names by copy - paste from a spread sheet file. I can do it one by one. That is time consuming. I have over 5000 Structures in one file. I have several of such files. I was on the lookout for an easier and swifter method.
Thanks.
Message 6 of 16
Joe-Bouza
This is what I do.
sort the structures by station, select in panorama and use the rename routine
sorting bt Northing or Easting will do as well.
in a real pinch you can select by plan in the order you wish
Joe Bouza
Message 7 of 16
Muthya
Thanks a lot.
I am looking for mass editing. I have thousands of structures whose name needs to be edited. It would be breeze if we could copy paste like in Excel. Wondering if there is any such possibility.
Also, can we think up a way to do it through the "Record - Replay" mode. Will check. This occurred to me while I typed this message. If you think it possible, please try and let me know too.
Thanks again.
Message 8 of 16
Joe-Bouza
Have you tried what I described? This is a mass edit.
the action recorder records you actions
Joe Bouza
Message 9 of 16
Joe-Bouza
Maybe Dynamo is the tool for the job
Joe Bouza
Message 10 of 16
Muthya
Not tried yet. But will do it soon and let you know the results.
Thanks for your help.
Message 11 of 16
Muthya
Not quite good at Dynamo.
Will try one of these days.
Thanks for the suggestion.
Message 12 of 16
Muthya
I have attached a video of my actions. This is what I can do.
I did not find a "Rename" command where I can change the entire list of names for structures in the Panorama. Do not know if I have missed something.
I could probably do it for Points for example.
Please let me know if there is any other workflow which can get me faster results.
Dynamo, currently is a long haul for me.
Thanks.
Message 13 of 16
cwr-pae
Maybe this will help?
Message 14 of 16
Muthya
Greetings.
Looks like it will help.
This is the first time I will be handling a VBA file. Where can I learn more about this?
Thanks.
Message 15 of 16
mjhon9911
Community Visitor
Community Visitor
When working in Civil 3D editing structure names is really about keeping things clear and consistent across the drawing, especially when multiple profiles or networks are involved. Using simple, readable naming conventions makes a big difference during reviews and collaboration. It actually reminds me of how people think about naming online profiles too—clarity plus a bit of structure helps recognition.
Message 16 of 16
freyaa9000
Community Visitor
Community Visitor
Renaming structures in Civil 3D can definitely get tricky, especially when trying to keep everything consistent across a project. I’ve found that using clear naming patterns or even quick text-formatting tools can help visualize names before applying them. For example, something like can give you quick variations and formatting ideas, which oddly helps when deciding readable naming styles. Small tweaks like that make large datasets much easier to manage later on.
