Civil 3D Forum
Dynamic Title Block Stretching issues
6 REPLIES 6
484 Views, 6 Replies
I'm trying to set up a dynamic titleblock. Instead of different visibilty states, I'd like stretch actions to allow me to set the different sizes.
My issue is that the folding lines I have on the perimeter of the titleblock don't behave as I want them to as I stretch the block. I want them to repeat along a certain module I've set up for them (185mm), and although I've gone through each visibility state carefully selecting which folding lines need to be seen and which done, the block does not behave as I'd like it to. (the folding lines don't even line up with the perimeter once exited from block editor!)
Any ideas?! I'm at my wits end here... I tried setting it up with Lookups but that didn't work better either... Any help would be very much appreciated!
I've attached some images to explain what I mean - my titleblock with the parameters and actions set up, a predefined visibility state to show where I want the folding lines, and finally the result once out of the block...
Thank you in advance!
6 REPLIES 6
Joe-Bouza
I went with visablity states and lookup tables to adjust the position of the attrubutes.
Mt dyno chops are not what they were a few years ago, but I would probably approach this with chained position paramaters on the folding lines. I would still use a lookup tables and hide the stretch grips.
example lookup1 would stretch to xy and move the folding lines to xy
the dyno board may get more feed back
http://forums.autodesk.com/t5/dynamic-blocks/bd-p/154
Joe Bouza
in reply to: Joe-Bouza
Thank you for your quick response but unfortunately I don't understand much of it... Excuse my novice position.. 'Mt dyno chops'?
tcorey
Add an array action for the fold lines. The stretch and array actions can both reference the same linear parameter.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Joe-Bouza
"My Dyno Chops" = my personal expertise with Dynamic blocks is not what it once was.
Joe Bouza
Pointdump
Joe,
I, too, was scratching my head over "Mt dyno chops".
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Joe-Bouza
in reply to: Pointdump
Its an Island in the south Pacific where I learned how to create Dynamic blocks, type and proof read. 😮
Joe Bouza
Rail Community
