DXF Feature Linework Using More Decimal Places Than CSV File
My Trimble Access controllers are set up with code lists that create feature lines based on specified codes. This linework is then able to be exported to .dxf format to be inserted into our drawings. The problem I'm running into is that the .csv is exported with 3 decimal places, while the dxf is exported with ~15 decimal places. This causes some errors in the workflow when working with surfaces. Is there a way to easily reduce the decimal places for the .dxf to 3? Or at least a way to get them to match in Trimble Access?
