Draw order doesn't display correctly
tkirbytrinity
tkirbytrinity
A persistent issue I've had is draw order not displaying correctly, even after a REGENALL.  It does print correctly and also displays correctly when I first open a drawing.  I find the issue is particularly common when I have polylines with nonzero Global Width beneath other objects.
I've attached an example where the light green objects are above the wide polylines in the draw order.
Is there a way to fix this?
Thanks!
EliANewlines
Can you attach the dwg?
