I print a drawing in 11X17 directly to my printer at the scale 1:1 and it work.
Then i printed to pdf with ''DWG To PDF.pc3'' and ''PDF Creator'' at the same scale, i printed the PDF with
the same printer and the drawing is reduced to 97%.
Is there a way to fix that.
Check if anywhere in the process you have Scale to Fit checked. The margins in a PDF don't always equal the margins a printer can handle.
Allen Jessup
CAD Manager - Designer
I've only switch the printer. All the parameter still the same.
Hi @fredericgougeon,
it sounds as the PDF printer drivers you used have different internal settings, such as page margins.
Let me repeat the issue to make sure I have understood correctly:
Is that correct?
Karsten.
