Civil 3D Forum
dwg to pdf
3 REPLIES 3
fredericgougeon
262 Views, 3 Replies
dwg to pdf
fredericgougeon
 I print a drawing in 11X17 directly to my printer at the scale 1:1 and it work.
Then i printed to pdf with ''DWG To PDF.pc3'' and ''PDF Creator'' at the same scale, i printed the PDF with
the same printer and the drawing is reduced to 97%.
Is there a way to fix that.
Fred
Construction Surveyor
dwg to pdf
Fred
3 REPLIES 3
AllenJessup
Check if anywhere in the process you have Scale to Fit checked. The margins in a PDF don't always equal the margins a printer can handle.
Allen Jessup
CAD Manager - Designer
Allen Jessup
fredericgougeon
I've only switch the printer. All the parameter still the same.
Fred
Fred
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @fredericgougeon,
it sounds as the PDF printer drivers you used have different internal settings, such as page margins.
Let me repeat the issue to make sure I have understood correctly:
  • Direct plot from Civil 3D to paper works fine (1:1)
  • Then you create two PDF plots, one with "DWG to PDF.pc3" one with "PDF Creator"
  • You open both PDF in the same program (i.e. Acrobat Reader) and plot to paper
  • Result: One PDF Plot (or both?) are reduced to 97%
Is that correct?
Karsten.
Karsten Saenger
Is that correct?
Karsten.
Karsten Saenger
Rail Community
