Hi @dsmapping
OK, you are using Global Mapper. If you import a Global Mapper file to display linework in Civil3D, then you should disclose the FORMAT that's coming out of Global Mapper, e.g, dwg, dxf, shapefile, etc.....
In addition to describing the format you are exporting from Global Mapper, you should look at the bottom to view the PROJECTION that GlobMap is using. What does it look like?
Image-1For example, if your GloMap projection is Texas SPCS, NAD83, Central Zone, feet, then it will look like the screen capture on the left. (Your actual Global Mapper projection may very.) If you, or Global Mapper, didn't assign a projection, then it will look like the one on the right that contains question marks.
Based on your description (BTW your description is still kinda vague) it sounds like the Global Mapper projection is NOT being considered so when the linework is imported, it plops down in the wrong place in C3D's modelspace.
Can you disclose the projection being used by GloMap (if one exists to begin with)? Knowing BOTH the GloMap projection AND the whether or not you've assigned a CoordSys to C3D's modelspace will go a long way in diagnosing your issue.
Chicagolooper
