Civil 3D Forum
DVIEW Twist
6 REPLIES 6
Keta-Salmon
3336 Views, 6 Replies
DVIEW Twist
I have a drawing that has been "Twisted" using the DVIEW Twist command. My question is, is there a way to untwist the objects back to their original orientation if I do not know the angle they have been twisted? Is there a way to see the amount of twist so I can undo it?
6 REPLIES 6
ACADuser
in reply to: Keta-Salmon
DVIEWTWIST will give you the value.  Use the PLAN command to change it back to normal.
ACADuser
Civil 3D 2018, Raster Design 2018
Windows 7 Enterprise
Dell Precision 5810 Workstation
Intel Xeon E5-1630 v3 @ 3.70GHz
32GB RAM, NVIDIA Quadro K2200 4 GB GDDR5
DUAL 27" Dell UltraSharp U2713HM
rkmcswain
Run the UCS command, Set it to World. (You may not need this step, but go ahead and do it anyway). Then run the PLAN command and either choose World or Current.
Make sure your UCS icon is on. Depending on your settings, there should be some indicator that you are in World (usually a "W" in the corner). Then as long as your plan view = World, you should be where you want to be.
R.K. McSwain     | CADpanacea | on twitter
Keta-Salmon
in reply to: ACADuser
Perfect. Thanks
sameermir
So using this command does fix the drawing (the north is fixed), but the lines you create orthagonal doesn't work properly
CahaLF7RX
in reply to: sameermir
Ortho  does work, the lines just match your courser angle.
you can reset the cross hairs with the Snap command
good luck,
nonbeard13
AllenJessup
in reply to: CahaLF7RX
I believe you mean SNAPANG.
Allen Jessup
CAD Manager - Designer
State of Sustainability Webinar
Rail Community
