I have a drawing that has been "Twisted" using the DVIEW Twist command. My question is, is there a way to untwist the objects back to their original orientation if I do not know the angle they have been twisted? Is there a way to see the amount of twist so I can undo it?
Solved by ACADuser. Go to Solution.
DVIEWTWIST will give you the value. Use the PLAN command to change it back to normal.
So using this command does fix the drawing (the north is fixed), but the lines you create orthagonal doesn't work properly
Ortho does work, the lines just match your courser angle.
you can reset the cross hairs with the Snap command
good luck,
nonbeard13
I believe you mean SNAPANG.
Allen Jessup
CAD Manager - Designer
