Duplicated Keyboard Shortcuts from different sources
Richard_Mehall
Richard_Mehall
I am trying to customize keyboard shortcuts. I noticed that I have duplicated from different sources (ACAD and CIVIL). What does this mean and where did they come from? Is this common and would it cause me problems? It looks like I can delete them but which one should I delete?
ianjchap
Hi @Richard_Mehall,
The duplicates look irrelevant as long as you change any quick keys for both ACAD & CIVIL, as they all seem to have the same equivalent. I think this could be due to Workspace settings ie. Civil3D/Drafting and Annotation or a hangover from merging information. As one set has a cross, the other a Tick I would say start with the Ticked changes and try those out.
Give it a try with just one or two and see how they're working before any drastic changes. 😊
Ian Chapman
If you found this post useful, please Like the post.
If this post helped you successfully solve your problem, then click on the ACCEPT SOLUTION button.
Richard_Mehall
Hey Ian, thanks for the quick reply. I'll give that a try and see how it goes. I guess I wanted some reassurance before I change anything!
AllenJessup
I checked it out. I don't see any from Map 3D. Just one from Raster Design and a couple from Add-on. But no Map. There are duplicates in a couple of Partial Customization Files.
This is normal. Everyone gets to add a little.
Allen Jessup
CAD Manager - Designer
Richard_Mehall
Sounds good thank you both!
