Draworder or display order
ESchomberg
Message 1 of 19
ESchomberg
I had a friend tell me about the draworder command while hatching solid asphalt; I thought it looked bad to have boxes of unshaded areas around text. He said " 1) draw polyline around area to be hatched. 2) hatch it 3) type draworder in command bar. 4) select the polyline encompassing the hatched area. 5) promt 'back' ". It worked....Now it wont work anymore Gawd!!!
One of my bosses said " I do it a different way ". he clicked on his hatched concrete, right clicked, clicked display order and then move to back. I can't get that to work either. Am I doing something wrong or is this software just messing with me?
Replies (18)
Message 2 of 19
tcorey
Don't select the polyline, select the hatch, and then set your Display Order/Draw Order.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 19
rl_jackson
Are you printing your solid hatch as a grayscale?  If I hatch anything solid then it's going to print in a grayscale and there's no need for boundaries around text. Also looks good, but you still may have to push the hatch pattern to the back every so often.
Rick Jackson
Survey CAD Technician VI
Message 4 of 19
ESchomberg
I tried that, it still does not work. I even flattened everything wondering if 3d had something to do with it.....it still hatches around the text instead of going under it.
Message 5 of 19
ESchomberg
Im not sure about the grayscale. I just select monocrome, plot transparency and hit print.
I believe by saying "no need to have boundaries around text" you are suggesting a setting to turn that off that I need to find lol. I have gotten much better at plotting thanks to you guys but I'm still not great at it.
Message 6 of 19
rl_jackson
You need to turn off island detection. The text is the island.
Rick Jackson
Message 7 of 19
lynn_zhang
Hello @ESchomberg ,
Just checking to see if your problem has been solved. Let us know if you still need help!
Lynn Zhang
Message 8 of 19
ESchomberg
Im sorry for not following up, im in the midst of buying a house.
May I ask before I follow up, is island detection in the properties box, or in settings?
Message 9 of 19
rl_jackson
Look at the hatch settings. There's options on how it will hatch.
Generally I place my hatch area on a layer that I can isolate hatch that area and undo the isolation. Almost all the hatch patterns I use are grey scaled so that any text can quickly be brought to the front.
Rick Jackson
Message 10 of 19
jefflambert9091
You can change the draw order through the hatchedit. It give you more options. Another option would be to do the opposite. Select everything in and around the hatch and put their draw order to front.
Jeff
Civil 3D 2024
Message 11 of 19
AllenJessup
Draworder has always seemed a bit flaky to me. I sometimes have to Select All, remove the object I want to be in the back and then bring everything else to the front.
I recently learned about a command LAYERORDER. That will set a plot order based on the layers. So if you put your hatch layer at the bottom of the list. It should plot last.
Allen Jessup
CAD Manager - Designer
Message 12 of 19
ESchomberg
Thanks to you, I forced myself to learn grayscale and I love it. Just pick a gray color, turn grayscale on and type a number in the box....Not so hard. I think It is better than transparency because transparency would not work on a block but grayscale did.
Message 13 of 19
ESchomberg
Yoda, you probably knew I was going to ask this question, but where the heck is island detection? I can't find it.
Message 14 of 19
rl_jackson
Should be to the right on the hatch ribon it's a little hidden but there is a pull down with options
Rick Jackson
Message 15 of 19
doben
There is another command you might want to try: "hatchtoback" It will move all hatching to the back without having to select it as will "texttofront"  bring all text to the front.
Message 16 of 19
ESchomberg
Darn it, I see the pull down box, but no Island detection. Are you using an older version maybe?
Message 17 of 19
Pointdump
Hey Erik,
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 18 of 19
ESchomberg
I started to click on one of those but didn't think it would be there. Thanks. I didn't quite dig deep enough.
Message 19 of 19
lynn_zhang
Hi @ESchomberg,
Was your problem resolved in the end? If so, remember to click on the "Accept as Solution" button from the replies above so this helps other users in the community find the solution too. Thanks!
Lynn Zhang
