I had just finished a job for a client, saved it, and when i reopened it, only the contents of the 0 layer are showing. The drawing preview (before opening up the .dwg file) shows my completed work.
All of my layers are set to "visible" and are "unthawed" and "unlocked"
the border and frame that is on my 0 layer has recent and updated information so I know it saved once it was completed.
Please help me display all the elements in my drawing that are visible on the "preview" on are not existent once the job opens.
attached the .dwg in question if it helps.
Solved by user181. Go to Solution.
Solved by AEC_Cadd. Go to Solution.
With the drawing not opened use the RECOVER command and browse to the drawing and select it. That will repair it.
