Drawing Files Open EXTREMELY Slow
Chaznsc
Message 1 of 15
Chaznsc
I am experience a 15 minute open time for my Civil3d 2015 project. Its only 9megs and yesterday is started this mess. I have purged, including -purge r, reset the profile, repair installed all to no avail. My neighbors machine flips it right open. It does the same thing in V2017.
Windows 10, Civil 3d 2015, 12gb, 256gb ssd
Help!
Replies (14)
Message 2 of 15
tmachado
Hi @Chaznsc, check this article and install the hotfix:
https://knowledge.autodesk.com/support/autocad-civil-3d/troubleshooting/caas/sfdcarticles/sfdcarticl...
Hope this will help!
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the LIKES button
Tatiana Machado
BIM Manager/ Autodesk Certified Instructor
Blog | Twitter | LinkedIn
InfraWorks Ambassador
Message 3 of 15
Chaznsc
I was just fixing to EDIT my thread, I also tried the degradation fix. No dice.
Message 4 of 15
tmachado
I will try to log in as you in another machine and open the same file to see if the problem is your user account permissions or the computer.
or the other way around somebody else to log in on your machine to try to reproduce the same issue
Tatiana Machado
Message 5 of 15
Chaznsc
I dont quite understand your response. Other machines this works seemingly fine on.
Message 6 of 15
tmachado
But what happens if you with your Microsoft user id log in another machine?
Does behave the same way?
Tatiana Machado
Message 7 of 15
Chaznsc
And if it did what would that mean? Nothing has changed on the network side and Civil 3d has been on this machine for 2+ years.
Message 8 of 15
tmachado
The problem could be corruption under your user account.
You need to troubleshoot the issue...
Tatiana Machado
Message 9 of 15
Chaznsc
Done, new account on same machine, file takes forever. Finally just crashed it.
Message 10 of 15
g_k50
Any other problems that might point to a problem with that particular machine?
I've go a couple of 75 meg surface files that take a few minutes to open, but nothing that would take as long as you indicate, and crashing is a problem.  I was surprised to get a Blue Screen of Death, not long ago, but nothing since.
I would look at the machine, are other big files doing the same thing when you try to open them?
Message 11 of 15
Chaznsc
I will have to start digging into the machine, but it could be anything. It's as if I stepped over a line and now it's under water. I'm not experiencing crashing, BSOD, no errors, nothing.
Message 12 of 15
tmachado
What is the difference between this machine and the one that works just fine...?
Do you have all updated drivers, hotfix and updates installed for windows and C3D?
Tatiana Machado
Message 13 of 15
Chaznsc
The other machine is a new unit, mines got a few years on it. It's been a great machine. As far as I know everything is up to date.
Message 14 of 15
Chaznsc
I have identified a potential lead in this investigation. If I chance my workspace to anything other than CIVIL3d the drawing opens as expected, mater of seconds after the lines appear on the display. If I try to change the workspace to CIVIL3d while in it, it will hang, or at least takes forever to make the change. I have already tried replacing the profile but that doesn't do anything but reset all my settings.
Message 15 of 15
Mike_Hurtado
Autodesk Support
Autodesk Support
You could try pulling a working Civil 3D cuix file from a machine that doesn't have the problem. You can grab the file from the following location:
C:\Users\<User>\appdata\roaming\autodesk\c3d 2015\enu\support\c3d.cuix
If the above doesn't work, then your best bet might be just starting fresh with a clean uninstall and reinstall:
2015: Clean install of Civil 3D
Make sure that you delete the folders and registry keys mentioned in the article to ensure that you're actually starting fresh
Michael Hurtado
Designated Support Specialist
