Somehow, I changed a setting and can no longer double click on text, xref's, etc. to edit them. I can only select them and edit in the Properties palette or in the External References ribbon. I'm not sure, but I think this happened right after installing SP1.
Solved by Jeff_M. Go to Solution.
In Options, User Preferences tab, top left is a check box for Double Click Editing.
Evidently, I've done something else to screw this up. I was already set to use double click editing and I even double checked my mouse click speed in Windows, but no go. I still can't get it to work.
