Civil 3D Forum
Double Click Editing
4 REPLIES 4
930 Views, 4 Replies
Somehow, I changed a setting and can no longer double click on text, xref's, etc. to edit them.  I can only select them and edit in the Properties palette or in the External References ribbon.  I'm not sure, but I think this happened right after installing SP1.
4 REPLIES 4
tcorey
In Options, User Preferences tab, top left is a check box for Double Click Editing.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
in reply to: tcorey
Evidently, I've done something else to screw this up.  I was already set to use double click editing and I even double checked my mouse click speed in Windows, but no go.  I still can't get it to work.
Jeff_M
PICKFIRST variable got changed. This must be 1 for dbl-click to work. (This is shown on the Selection tab in Options as the Noun/Verb selection option...this should be checked on)
in reply to: Jeff_M
Excellent, thank you.
Rail Community
