Do *sid files have a know performance issue with civil3d?
Joe-Bouza
Mentor Mentor
Message 1 of 13
Joe-Bouza
Asking for a friend
Joe Bouza
Replies (12)
Message 2 of 13
rl_jackson
Joe,
Personally I've not seen any issues with SIDs as of late, there was a point were there was a format change that Adesk didn't keep up with that wouldn't allow them to load. Performance wise, I really don't use them enough to elaborate, we do get the most current ones for our projects but I generally prefer to just use the Bing maps, I'm not publishing anything with aerials often, its just reference.
Rick Jackson
Survey CAD Technician VI
Message 3 of 13
Joe-Bouza
Thanks Rick.
i prefer the jp2 the state DOT makes available. Some counties still have sid and that’s where I am, unfortunately.
i will see today if it’s the Sid or my VPN.. which is usually fairly reliable.
the resolution of the online maps - that’s what you mean by Bing? - is ok for some design work but we often include an aerial plan, and the DOT maps are good for that.
Joe Bouza
Message 4 of 13
ChicagoLooper
Not all sid files are supported.
How are you bringing in the sid file? Are you using Raster Design, a civil3d command or the Data Connect Palette?
You can read the knowledgebase >>HERE<<.
Chicagolooper
Message 5 of 13
AllenJessup
Yeah. They're good. But we're thinking of contracting with some place like Nearmap. The images currently on the State site for my area are 5 years old. Last years fly is supposed to be up soon. But things change so quickly. We'd like to get a flight twice a year. Plus, if the money is right, obliques and point clouds.
Allen Jessup
CAD Manager - Designer
Message 6 of 13
Joe-Bouza
I hear Nearmaps is a good alternative. LI has 2020 jp2 and Yonkers is a 2018 sid hole
Joe Bouza
Message 7 of 13
Joe-Bouza
MAPIIMPORT. No issue getting them in.
only 8 tiles and acad is crushed
Joe Bouza
Message 8 of 13
AllenJessup
I usually import the images into a blank drawing and Xref that into my project.
Allen Jessup
Message 9 of 13
ChicagoLooper
Try using the Data Connect Palette. Yes, you can use MAPIINSERT but just because you can, doesn't mean you should. <<I think you meant MAPIINSERT, not MapImport. The former imports rasters while the latter imports vectors.>>
Once you've connected to your raster, do this:
  1. Assign the appropriate coordinate system, e.g. State Plane and Zone, UTM/zone, etc.
  2. Open the Data Connect Palette=>>'Add Raster Image' by browsing to and selecting your SID file. On command line enter MAPCONNECT==>The Data Connect Palette opens. Click 'Add to Map' and your image appears in modelspace.
  3. Open the Map Task Pane. On command line enter MAPWSPACE==>'O' for Open==>The Task Pane opens.  Your image will be listed as a LAYER in the Task Pane.
  4. In modelspace, pan and zoom-in on your target area, leaving the unnecessary portions, such as the outer edges, out-of-view and offscreen.
  5. Back in the Task Pane, right-click the SID layer listed in the Task Pane==>Resample Raster=>Image reduces to the limits of the 'monitor-view' while the offscreen portions are no longer displayed.
Pan around. Zoom in and out. Does performance improve?
To return to the original extents of the raster, use mouse wheel to zoom out. Use your judgement to determine whether you've zoomed out enough to 'view' the entire image had you not executed resample raster earlier. Next, perform step 5 again and the raster will resample to monitor-view or the outer edges of your original SID image .
Chicagolooper
Message 10 of 13
Joe-Bouza
Yes, MAPIINSERT, and I am also comfortable using FDO connect. they both bring the images in and the performance does not change. If I do the same with the same number of jp2 files performance is fine.
Joe Bouza
Message 11 of 13
ChicagoLooper
Sid raster are typically ‘wide-range.’ They cover a wide, super wide, area of land. They are typically high resolution and taken from high altitude. They are heavy files and need to be compressed. To use them your program must decompress them and that takes times and energy, hence the slow down.
Resample the raster to ‘reduce’ the data. BTW you can’t resample unless you use the Map Task Pane and using the task pane means you gotta abandon MAPIINSERT command.
Chicagolooper
Message 12 of 13
Joe-Bouza
You make it sound like I have an aversion or lack of competence to/ with the map task pane. Not sure why, but I have a nagging suspicion.
Joe Bouza
Message 13 of 13
atraverL6BDG
Community Visitor
Community Visitor
I am having the same issue with the *.sid files over VPN. No issues using 360 or while working local. The *.jp2 files are sluggish over VPN, but not as bad as the *.sid.
