Civil 3D Forum
diverting first flush in Hydraflow
0 REPLIES 0
Message 1 of 1
382 Views, 0 Replies
In the HYDRAFLOW program, I am using the diversion tool to take out the first flush from my incoming HydraFlow and routing that thru a treatment structure. The remainder flow will get routed around the structure into the downstream pipe.  The incoming hydrograph I want to split has a flow of 71.93 cfs, with volume of 197,407.
For diversion 1, I am routing 61,301 cf into a treatment facility.  That  output for diversion 1 shows a flow of 69.05 with that volume.
Diversion 2, shows 71.93 cfs and volume of 131,231.
The flows that are showing with each diversion are the same/inaccurate.  However, the volumes seem reasonable.  I am worried the output (flow wise) is not what it needs to be as I route this thru the system.
Any help would be appreciated.
Dawn Danley, PE
0 REPLIES 0
Rail Community
