Civil 3D Forum
Digitale Geländemodelle
7 REPLIES 7
Message 1 of 8
366 Views, 7 Replies
Hallo, ich habe öfters das Problem, daß Grenzlinien bei digitalen Geländemodellen falsch angewendet werden. In diesem Fall habe ich eine 3D Polylinie als Grenzlinie erstellt. Civil (2018) wendet diese aber nicht richtig an. Hat jemand auch dieses Problem oder eine Lösung dafür?
Tags (3)
7 REPLIES 7
Message 2 of 8
Pointdump
Nils,
"Civil (2018) wendet diese aber nicht richtig an."
Please elaborate with more details about what isn't working. Screen shots or posting your data or drawing will help.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 3 of 8
in reply to: Pointdump
Hallo Dave, ich habe gerade versucht die Situation mit der 2019er Home-Use Lizenz nachzustellen. Da scheint es zu funktionieren. Ich kann Dir erst wieder morgen antworten, da ich dort mit Civil 2018 arbeite.
Danke erst einmal!
Message 4 of 8
Dave, I've already created an e-Transmit for you. It's about the DGM "Verkehrsflaechen1").
Greetings...
Message 5 of 8
Pointdump
Nils,
I did a RECOVER on your drawing. There were a few problems:
Dave
Dave Stoll
Las Vegas, Nevada
Message 6 of 8
Pointdump
Nils,
In your Verkehrsflaechen1 Surface, how were the Bruchkante_gesetzt breaklines created? I can zoom to, but not select, most of them. Strange.
Dave
Dave Stoll
Las Vegas, Nevada
Message 7 of 8
Dave, that's a problem that's constantly cropping up in Civil 2018. When you create a new drawing, it doesn't take long for errors to appear in the drawing. Then every time you do this, you have to use the drawing utilities to fix the problem. This happens at all our Civil workstations.
Message 8 of 8
Hi Dave, I deleted the models and created them again. I found out that if you select the boundary line before clicking "Add Border Lines", the boundaries will be applied correctly. Why ever that is, as long as it works, that's enough for me. So we don't need to investigate any further.
Thank you very much!
Rail Community
