Diffrent view of section views from corridor
mateusz.dunaj
mateusz.dunaj
I  have some big problem, a lof of section  views show bad in  section  Veiw -  but in  corridor editor it's looks good ...
how solve this issue ???
Karadzhaian_Eduard
Hi @mateusz.dunaj ,
Try to assign equal code set styles for corridor and in Properties then you create sample lines.
I think that some link's codes are not imported (or have invisible style) in code set style you're using in section views.
Try to:
  1. tune your using set style in section views;
  2. import all codes choosing all your assemblies:
Eduard Karadzhaian
Senior Civil Infrastructure Engineer
Blog| LinkedIn| E-mail| Youtube|
mateusz.dunaj
noppe, not help.
I thicknes corridor by 1m -  it's help  a lot but :
- kill pereromance
- not working in  all case.
Hi
that issue relation to corridor surface
can you attach dwg to examine it.
cwr-pae
With out seeing the drawing I think it is caused by a sample line at a station that is not an assembluy insertion station. Under the corridor add a section at each station that has this issue. If that cures most but not all, you may have to edit the surface triangles to have the tin lines follow the sample line direction for the remainder.
