Grading Group - (Surface by slope; Lines not showing up)
Message 1 of 1
Hello.
I'm trying to create a dam using grading group. With 2 Featurelines (edge of  dam) and sloping 1:2 to existing surface.
2019-07-12 13_46_53-Autodesk Civil 3D 2019 - [C3D_SURFACE_DESIGN.dwg [C3D DATA SHORTCUT]].png
However, the line where it daylights is not showing up.
2019-07-12 13_59_27-Autodesk Civil 3D 2019 - [Drawing2.dwg [C3D DATA SHORTCUT]].png
It will, however, show up when you go use object viewer.
Even creating a surface from the grading group will still work.
2019-07-12 14_06_30-Autodesk Civil 3D 2019 - [Drawing2.dwg [C3D DATA SHORTCUT]].png
I was thinking of a workaround to just go to surface properties and show border of the surface.
But I really wouldn't want to do it that way.
Has anyone of you had this problem before?
Thanks.
Replies (0)
