Design Center Layer Reset
raaker
Message 1 of 9
raaker
I use Design Center periodically to copy a Layout from one drawing to another so I can get the viewports in the same spot, but change a few things on it. For some reason when some of us in the office do this it has been resetting all of the viewport layer settings so all Layers are thawed, which can be overwhelming to deal with in some of our more compilicated drawings. Does anyone know a way to keep the layer setting from the original drawing file when adding to a different drawing file?
Replies (8)
Message 2 of 9
tcorey
In the destination drawing, toggle the value of VISRETAIN.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 9
raaker
We have VISRETAIN set to 1, what should we have it set to?
Message 4 of 9
Joe-Bouza
Try hitting layer previous immediately after
Joe Bouza
Message 5 of 9
tcorey
Toggle it to 0.
Tim Corey
Redding, CA
Message 6 of 9
raaker
That didn't work, I set both drawings to 0 VISRETAIN. Do you have any other ideas?
Message 7 of 9
J-Porter
Do the drawings both have a layer states manager that is named the same?  If so, could one layer state be overwriting the other?
Message 8 of 9
raaker
Did not work. All of the VP layer settings are set to thawed when I do this. Some of my co-workers do not have this issue when adding layouts through design center so I must have some setting set different in my software.
Message 9 of 9
ChicagoLooper
Hi @raaker
When using Design Center are you adding the OTHER dwg? Don't copy the other drawing's template (DWT). You'll need to browse-to then add the target LAYOUT TAB from the actual DWG itself. Make sure you have saved that other drawing with the desired layers either frozen or thawed. The Design Center will add the layout based on that drawing's last save.
If some users in your office are having success while others are not, you'll need to look over the shoulder of those who can't do it and watch their monitor to find out what they're doing wrong. (Or look over the shoulder of good users to find out what they're doing right.)
Chicagolooper
