Description Key Coding w/Wildcards
Message 1 of 16
C3D 2016 Win7
How can I get description keys to work on similar codes. It is easiest to use an example:
MH = generic manhole
MHE = electric manhole
MHST = storm manhole
code may include additional info, like MHST.48
if I use codes as follows:
MH*
MHE*
MHST*
will MHST.48 come in according to description key parameters defined for MHST*? If not, how can I set up the description key codes to make this happen?
I cannot change the point codes.
thanks
Replies (15)
Message 2 of 16
rl_jackson
Yes the MHST.48 will allow the MHST Point to come in. What is the .48 for, and if your planning on using that in the point description use a space instead.
EX: MHST 48 where point descriptin would be $1" Storm Manhole and would read 48" Storm Manhole in the drawing.
Rick Jackson
Survey CAD Technician VI
Message 3 of 16
rl_jackson
Better Example same principal
Rick Jackson
Message 4 of 16
BrianHailey
In your example, anything that starts with MH will be coded as a generic manhole UNLESS the next letter is an E or the next two letters are ST.
MH=generic
MHX=generic
MH1234=generic
MHE=electrical
MHEX=electrical
MHE1234=electrical
MHST=storm
MHSTX=storm
MHST1234=storm
MHS=generic
MHET=electrical
At least, the five minutes of testing since I first read this post indicates this is how it works.
Hope this helps.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 5 of 16
48 would be diameter of structure. there could be any number of attributes to any number of codes.
we use a decimal because plot codes are seperated by spaces.
so again, MHST -or- MHST.48 would come in on the MHST* layer, and not MH*? how does it know that the "ST.48" after "MH" is not covered by the wild card in desc. key MH*?
Message 6 of 16
thanks, Brian,
I believe that this answers my question.
Message 7 of 16
BrianHailey
I think it's because there's another key that matches it "better".
GEI Consultants
My Civil 3D Blog
Message 8 of 16
rl_jackson
If you intend on using the 48 as part of the point description you will need to use a space, the period will not work with description keys. The intent of the wildcard is for additional descriptive information in the point label, as I showed in my screen shot previously using a similar description key with the FD........, anything placed after this must contain a space, this defines its position in reference to the $0 $1 $2 scenario. (i.e. FD*=$0) anything else would be count up from there, so a raw code of FDCIP 1 LS1234 would have a key of FDCIP* and a point description in the key of Found 1" Capped Iron Pipe "LS1234" where 1 inch would be $1 and LS# would be $2.
If you plan on using multiple attributes for a single manhole (I'm assuming your intending to place measurements to inverts), you'll need to define a new point file format the would be comma delimited for the with additional attribuites defined using the Point - User Defined Properties, as additional fields above and beyond your PNEZD so your would need a PNEZDA1A2 etc.....
HTH
Rick Jackson
Message 9 of 16
My big question with spaces is how you incorporate plot codes?
if you had a 24 in. curb and coded TC 24 ST (for start line) for the beginning of a 24 in. top of curb - will that work? what about underbars? I've got my field people trained to NOT use spaces because of the way Inroads imports linework.
I work with other agencies that use Microstation, and I *have* to have spaces before plot codes as our city wide standard.
Message 10 of 16
rl_jackson
With C3D the raw description delimiter is locked to just one or the other You can change the defaults in the linework code set, (i.e. B or BEG to ST) The field delimiter by default is a space, so if this is change it affects description keys as well, its all relevant.
Rick Jackson
Message 11 of 16
Resurrecting this topic. The description keys work fine. Today's question is this:
How do I get point groups to behave similarly? My Sanitary point group (ex. MHS for Manhole, Sanitary) includes storm sewer points (MHST, Manhole, Storm).
Is there a way to have it differentiate between MHS & MHST? I am using Raw Description to sort the points into groups. The obvious way that appears to me is to Exclude points with raw description MHST*. But it'd be cleaner and easier to have a global setting, obviously. Is there such a thing?
Message 12 of 16
point group problem solved by using Exclude tab.
same issue with survey figures using wildcards. BS=buried sanitary BSS=buried storm sewer. survey figure BSS1 is going to figure BS* (buried sanitary)
Message 13 of 16
rl_jackson
Survey figures don't use a wild card. The figure prefix is just that a prefix. You need to have different codes like BSS and BST. Then your figure prefix should be the same as the code.
Sometimes less is not always better when doing figure prefixes.
Rick Jackson
Message 14 of 16
rl_jackson
I would also recommend that for your storm and sanitary point group issue so you code MHST or MHSS
Rick Jackson
Message 15 of 16
They apparently *d0* use wild cards. Unless they don't need the asterisk to behave the same way? All I know is that BSS1 (storm sewer) went to the BS (sanitary) figure.
I work for a city with several autonomous agencies. We all share data. Any change in coding would have to involve everyone. I can always suggest it, though.
Thanks for the input.
Message 16 of 16
rl_jackson
BSS and BS will require a code change. There is no question in that. Figures have worked the same way with respects to prefix since the DOS days.
What is happening is it's seeing BS and stops reading anything after that hence the reason there called figure prefixes
Rick Jackson
