Any ideas on how to delete part sizes in a part list all at once?
Just delete the part family, then re-add the parts you need. Not great but that is the best we have. Not sure if project explorer has more options.
Welcome to the Civil 3D forum. Thank you for submitting your question in our discussion forums.
It looks like Neil provided you with the steps to delete multiple part sizes. Did the suggestion help?
Please let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
when you have them all highlighted like that, hit the delete key. It works on my machine, that is how I typically build a list, drop all the parts in and then delete all the parts I dont need. If the delete key is not working for you, right clicking should have a delete option.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
Chris, delete doesn't work for me, nor does right click give delete option. This is for pipe parts. C3D 2023.
My bad, I just tested this in 22-24 and it doesnt work for gravity. I'm so used to working in pressure recently that is where my workflow came from.
