Hello All,
I have a street with a meandering sidewalk. I have an assembly with the street section, a lanscaped section, a 10' sidewalk, and a daylight respectively.
The problem I'm having is this: the sidewalk is targeting two polylines (inner and outer edges). The daylight modeling starts at a constant distance from the centerline (like the assembly is drawn) without taking into consideration the outer sidewalk target. Is there any way to make the daylight begin after the sidewalk target? The daylight subassemblies that I've tried do not have a polyline target for me to use.
Solved by klugb. Go to Solution.
Solved by Simon_Blain. Go to Solution.
Corridor problems almost always need a dwg file for people here to diagnose due to the vast number of variables/permutations.
You can attach the daylight subassembly to the sidewalk so when it moves to follow the horizontal target the daylight shifts also.
Like CWR said a drawing would help. Can you screenshot out the assembly at least?
Here is my assembly. I have the daylight attached to the end of the meandering walk on the right side of the assembly. As I stated before, the sidewalk is meandering so I am targeting the inside and outside of the subassembly to polylines. However, when I do so, the daylight assembly does not shift with it.
My only thought was that I could use a daylight subassembly that could target the same outside width polyline to "start" the daylight, but I didn't find any such daylight subassembly that could target a polyline for the beginning of the daylight.
Any help would be awesome.
As Jeff said right-click on the subassembly and see if this is an option.
Here are the three relevant pictures. The daylight is correctly attached to the assembly. The Sidewalk correctly targets the meandering sidewalk polylines. The issue is that the daylight assembly continues to begin x feet offset from centerline without taking into account the meandering sidewalk targets. The x offset from centerline is the distance in the assembly without polyline targeting.
Edit: I also tried offsetting the outside sidewalk polyline the 2 feet for the bench and adding a third target for "Outside boulevard width" which did nothing as well.
Can you post the drawing or email it?
It would be a lo easier to resolve the issues.
bruce (dot) klug (at) clark.wa.gov
Is your daylight subassembly attached to another part of your assembly but it has an offset in it so it looks like it's attached to the end of the sidewalk ?
The daylight is attached to the end of the sidewalk's bench section and does not have an offset. The modeling of the daylight continues to begin at the x offset of the centerline with x being the length before any polyline targeting takes place.
See the grouping of your subassemblies, the urbansidewalks are not connected to group 11 and group 12, neither is the daylightmultiintercept who's in his own group.
There might be a better way to change it but the one I know (haven't had to change this often) would be to recreate your assembly from scratch and make sure there is only 2 groups, left and right. Inside those group the subassemblies must be in the correct order from top to bottom.
Try this and I'm pretty sure it's gonna work 🙂
Your daylight is not attached to the sidewalk. Grip the daylight and rt-click select "Move to" and pick the back of sidewalk. Then rebuild your corridor.
