@Sinoj.Ravindran,
You can post it separately so that others can discuss and once we found solution and conclusion can accept as a solution which will helps others.
Yes i have worked on infrastructure projects (Subdivision Design) and used datashortcuts method for both roads and pipe networks.
Regarding issue of synchronization on pipe networks,
make sure that you have installed the fix available for for pipe network reference issues, this is required and works for civil 3d version from 2018 to 2020. If you have installed and everything is upto date then will try with these,
1. Audit the drawing if there is any errors in the drawing it will fix the errors.
2. Purge and -Purge<<Regap option.
3. In the sheet file make sure that data shortcuts is properly done with set working folder and project folder is assigned correctly and also shortcut project is assigned with current sheet file or drawing file.
4. Validate the datashortcuts.
5. After applying step 1 to 4 issue not resolved, go to civil 3d model or source drawing, check the reference path remove old shortcut files and recreate the reference and save the file and close, now go to sheet file open the drawing and try to synchronize the reference or enter command SYNCHRONIZEREFERENCES. Also check and play with PIPENETWORKSYNCMODE variables.
Feel free to share the file so that can have a look properly and find the solution.
I recommend you to ETRANSMIT the drawing if in case of sharing here or in Inbox.
Did you found this post is unique ? Hit Like Button.
Did this post resolved your issue? Hit Accept as Solution & Like Button. This will be helps others to solve the issue.
Cheers,
Neil
Project Manager | Civil | ACE Inc.
Certified Civil 3d Professional | YouTube | My-Blog
