Hi Guys,
Looking for a method or if anyone know how to create a cut and fill for different levels of a surface?
So if I create my combined Design level surface and create my volume surface using the EG as a Base will this only be for the top layer?
if I want to incorporate all of it so id get a cut and fill volume down to the subbase what would be the way to do this?
I know I could probably create a duplicate surface and then just lower the surface the difference but I don't know if this would work?
Solved by Pointdump. Go to Solution.
Hi Nathan,
Jeff Bartels to the rescue >>>Here<<<.
Dave
Dave Stoll
Las Vegas, Nevada
Bartles is great. You can build a surface from each layer and volume accordingly
Joe Bouza
