Could someon tell me why in my section the cut and fill don't appear?
I made the cut and fill subassembly, but they are not included.
Solved by Joe-Bouza. Go to Solution.
Solved by Jeew-m. Go to Solution.
I think you have not sampled corridor in to the sample lines.
Select a sample line/section view
From ribbon select add more sources
Add the corridor
Eu fiz, mas não funcionou.
A superfície do corredor também não está indo bem. Minha montagem tem os cortes, mas a superfície do corredor é diferente.
Did you include the target surface assignment?
Joe Bouza
