Custom Side Ditch with Shoulder subassembly issue
NeoAlpha
NeoAlpha
Hello everyone,
I have created a custom side ditch that is attached to a shoulder, which is as one subassembly, when imported into civil 3d. I want the side ditch to look straight and not bent, as indicated by the number 2 in image 2. the connection of the shoulder near the number 1 should connect to the side ditch but still maintain the thickness of the subbase, whenever the shoulder superelevates. I have tried for 3 weeks but still cannot get it to work, please I need your help.
See attached is the subassembly, and the images.
Accepted solutions (3)
Replies (8)
Dexterel
give me 1 and a half hour and I will fix it
Dexterel
Fix some slopes and convert delta X-s to delta Y-s.
Small note: Link L51 has 0 slope so be sure to take into consideration, this means L5 length=L1 length-Trim, if you need P20 to coincide with P27.
New Parameters:
Use superelevations: if "Yes" it will use superelevation if superelevation is declared (presence) otherwise uses ShoulderSlope parameter.
Type of superelevation: In your case it will be outside shoulder. Note if subassambly is on the right it will use right outside shoulder and so on.
Formula for slope:
if(SA.islayout or Use_super=No,ctype(ShoulderSlope,Double),
if(Side=Left,
 if(super_type.value="OutsideLane",
  if(SE.HasLeftLO, ctype(SE.LeftLO,Double), ctype(ShoulderSlope,Double)),
  if(super_type.value="InsideLane",
   if(SE.HasLeftLI, ctype(SE.LeftLI,Double), ctype(ShoulderSlope,Double)),
   if(super_type.value="OutsideShoulder",
    if(SE.HasLeftSO, ctype(SE.LeftSO,Double), ctype(ShoulderSlope,Double)),
    if(super_type.value="InsideShoulder",
     if(SE.HasLeftSI, ctype(SE.LeftSI,Double), ctype(ShoulderSlope,Double)),
     ctype(ShoulderSlope,Double)  )   )  ) ),
 if(SE.HasRightLO, ctype(SE.RightLO,Double), ctype(ShoulderSlope,Double)),
 if(SE.HasRightLI, ctype(SE.RightLI,Double), ctype(ShoulderSlope,Double)),
 if(SE.HasRightSO, ctype(SE.RightSO,Double), ctype(ShoulderSlope,Double)),
 if(SE.HasRightSI, ctype(SE.RightSI,Double), ctype(ShoulderSlope,Double)),ctype(ShoulderSlope,Double)) ) ) )))
Dexterel
One more thing.
I change the SA so WallHeight represents the vertical distance mentioned in the attached image. SideSlope no longer influences this distance. This is way i change the points form deltaX-s to deltaY-s.
Jowennl
Hi @NeoAlpha,
Just a suggestion. Probably similar to @Dexterel.
Please see suggestion below and attached PKT:
Animated GifAnimated GifFormula usedFormula usedadd infoadd info
General Notes:
1) I remove AOR as it confused me.
2) I use math.abs to always show correct value.
Cheers,
Jowenn
Dexterel
one of the problems I fix is the WallHeight. Change the WallHeight and you will see it.
NeoAlpha
That was awesome, thanks Dexerel and Jowenni.
The wallheight was also a very great fix as I can also change the wallheight without any issue. I tested both .pkt and they both worked great. Thanks once again.
Dexterel
You miss L15 and P16. The Height should be fix (to 0.1)and not dependent on Sideslope.
Same for P29.
