Civil 3D Forum
Custom Side Ditch with Shoulder subassembly issue
8 REPLIES 8
Message 1 of 9
NeoAlpha
1282 Views, 8 Replies
Hello everyone,
I have created a custom side ditch that is attached to a shoulder, which is as one subassembly, when imported into civil 3d. I want the side ditch to look straight and not bent, as indicated by the number 2 in image 2. the connection of the shoulder near the number 1 should connect to the side ditch but still maintain the thickness of the subbase, whenever the shoulder superelevates. I have tried for 3 weeks but still cannot get it to work, please I need your help.
See attached is the subassembly, and the images.
8 REPLIES 8
Message 2 of 9
Dexterel
in reply to: NeoAlpha
give me 1 and a half hour and I will fix it
Message 3 of 9
Dexterel
in reply to: Dexterel
Fix some slopes and convert delta X-s to delta Y-s.
Small note: Link L51 has 0 slope so be sure to take into consideration, this means L5 length=L1 length-Trim, if you need P20 to coincide with P27.
New Parameters:
Use superelevations: if "Yes" it will use superelevation if superelevation is declared (presence) otherwise uses ShoulderSlope parameter.
Type of superelevation: In your case it will be outside shoulder. Note if subassambly is on the right it will use right outside shoulder and so on.
Formula for slope:
if(SA.islayout or Use_super=No,ctype(ShoulderSlope,Double),
if(Side=Left,
 if(super_type.value="OutsideLane",
  if(SE.HasLeftLO, ctype(SE.LeftLO,Double), ctype(ShoulderSlope,Double)),
  if(super_type.value="InsideLane",
   if(SE.HasLeftLI, ctype(SE.LeftLI,Double), ctype(ShoulderSlope,Double)),
   if(super_type.value="OutsideShoulder",
    if(SE.HasLeftSO, ctype(SE.LeftSO,Double), ctype(ShoulderSlope,Double)),
    if(super_type.value="InsideShoulder",
     if(SE.HasLeftSI, ctype(SE.LeftSI,Double), ctype(ShoulderSlope,Double)),
     ctype(ShoulderSlope,Double)  )   )  ) ),
 if(SE.HasRightLO, ctype(SE.RightLO,Double), ctype(ShoulderSlope,Double)),
 if(SE.HasRightLI, ctype(SE.RightLI,Double), ctype(ShoulderSlope,Double)),
 if(SE.HasRightSO, ctype(SE.RightSO,Double), ctype(ShoulderSlope,Double)),
 if(SE.HasRightSI, ctype(SE.RightSI,Double), ctype(ShoulderSlope,Double)),ctype(ShoulderSlope,Double)) ) ) )))
Message 4 of 9
Dexterel
One more thing.
I change the SA so WallHeight represents the vertical distance mentioned in the attached image. SideSlope no longer influences this distance. This is way i change the points form deltaX-s to deltaY-s.
Message 5 of 9
Jowennl
Hi @NeoAlpha,
Just a suggestion. Probably similar to @Dexterel.
Please see suggestion below and attached PKT:
Animated GifAnimated GifFormula usedFormula usedadd infoadd info
General Notes:
1) I remove AOR as it confused me.
2) I use math.abs to always show correct value.
Cheers,
Jowenn
Message 6 of 9
Dexterel
in reply to: Jowennl
one of the problems I fix is the WallHeight. Change the WallHeight and you will see it.
Message 7 of 9
Jowennl
Message 8 of 9
NeoAlpha
That was awesome, thanks Dexerel and Jowenni.
The wallheight was also a very great fix as I can also change the wallheight without any issue. I tested both .pkt and they both worked great. Thanks once again.
Message 9 of 9
Dexterel
You miss L15 and P16. The Height should be fix (to 0.1)and not dependent on Sideslope.
Same for P29.
Rail Community
