I have a pipe network with several curves. Each curved section is displaying the wrong lineweight and printing that way also. Any thougts how to fix this?
Solved by troma. Go to Solution.
Hello Cneely,
Thank you for choosing the Autodesk Forums. My name is Danneris and I will be helping you with this Service Request.
I understand that in Civil 3D, your curved section is displaying the wrong lineweight and printing that way and I will be more than happy to help you.
I really would like to know if I understood the problem you are experiencing, so in order to solve this inconvenience, please visit the link below for a possible solution suggestion:
Please, let me know if this suggestion helped you. If this is not your issue, please provide me a screenshot or a test file so we can troubleshoot this issue in order to help you find the proper solution. If I do not hear from you, I will follow-up.
Best regards,
Hello Cneely,
Thank you for your recent support inquiry. I wanted to follow up with you regarding my previous email. I wanted to see if you received the information I provided and if it allowed you to resolve this request.
If you consider your support request resolved, please let me know. If you require more help, please respond and I am happy to continue assisting you. If I have not heard back from you I will assume your issue is resolved.
I look forward to hearing from you soon
No, that workaround isn't applicable. I'm not using pressure pipe and I'm displaying only the centerline of the pipe already.
I wanted to bump this post and add a screenshot. Pipe network line segments display lineweights correctly, curved sections do not. Any thoughts or ideas?
Mark Green
Working on Civil 3D in Canada
here's a shot w/ labels. notice the difference in line weights. both pipes are the same style but the curved section wont properly display the line weight.
Mark Green
here's a screen shot of the pipe style. let me know if you see anything amiss.
Mark Green
that did the trick. thanks for the help!
