Civil 3D Forum
Curved pipe not displaying lineweight
11 REPLIES 11
Message 1 of 12
cneely
809 Views, 11 Replies
I have a pipe network with several curves. Each curved section is displaying the wrong lineweight and printing that way also. Any thougts how to fix this?
AEC Collection 2022
WIN 10 PRO
Dell 3650, Intel i9-11900k @ 3.50GHz, 64 GB
NVIDIA QUADRO RTX 4000
http://www.cobbfendley.com
11 REPLIES 11
Message 2 of 12
Danneris
in reply to: cneely
Hello Cneely,
Thank you for choosing the Autodesk Forums. My name is Danneris and I will be helping you with this Service Request.
I understand that in Civil 3D, your curved section is displaying the wrong lineweight and printing that way and I will be more than happy to help you.
I really would like to know if I understood the problem you are experiencing, so in order to solve this inconvenience, please visit the link below for a possible solution suggestion:
Curved pressure pipe components display when on non-plot layer
Please, let me know if this suggestion helped you. If this is not your issue, please provide me a screenshot or a test file so we can troubleshoot this issue in order to help you find the proper solution. If I do not hear from you, I will follow-up.
Best regards,
__________________________
Danneris Martinez
Technical Support Team
www.autodesk.com
Message 3 of 12
Danneris
in reply to: cneely
Hello Cneely,
Thank you for your recent support inquiry. I wanted to follow up with you regarding my previous email.  I wanted to see if you received the information I provided and if it allowed you to resolve this request.
If you consider your support request resolved, please let me know. If you require more help, please respond and I am happy to continue assisting you. If I have not heard back from you I will assume your issue is resolved.
I look forward to hearing from you soon Smiley Happy
Danneris Martinez
www.autodesk.com
Message 4 of 12
cneely
in reply to: Danneris
No, that workaround isn't applicable. I'm not using pressure pipe and I'm displaying only the centerline of the pipe already.
AEC Collection 2022
WIN 10 PRO
Message 5 of 12
cneely
in reply to: cneely
I wanted to bump this post and add a screenshot. Pipe network line segments display lineweights correctly, curved sections do not. Any thoughts or ideas?
AEC Collection 2022
WIN 10 PRO
Message 6 of 12
troma
in reply to: cneely
Staring at your screenshot...trying to tell what I'm meant to be looking at...can't figure it out.
Any chance you can turn off all the other layers?
Mark Green
Working on Civil 3D in Canada
Message 7 of 12
cneely
in reply to: troma
here's a shot w/ labels. notice the difference in line weights. both pipes are the same style but the curved section wont properly display the line weight.
AEC Collection 2022
WIN 10 PRO
Message 8 of 12
troma
in reply to: cneely
No real ideas.
Just wondering, what do you have the lineweight set to in the pipe style?
ByLayer, ByBlock, or something else?
Mark Green
Message 9 of 12
cneely
in reply to: troma
here's a screen shot of the pipe style. let me know if you see anything amiss.
AEC Collection 2022
WIN 10 PRO
Message 10 of 12
troma
in reply to: cneely
Not that it's "amiss" per se. But if this is a glitch, I'm trying to think of a way around it.
Your centreline lineweight is set to 0.90mm in the style. Try setting it ByLayer, and put the layer to 0.90mm. Either that, or set it ByBlock. Then select all the pipes and set the lineweight in the properties box.
Mark Green
Message 11 of 12
cneely
in reply to: troma
that did the trick. thanks for the help!
AEC Collection 2022
WIN 10 PRO
Message 12 of 12
troma
in reply to: cneely
Cool, glad it worked!
Mark Green
Rail Community
