Crossing Utilities - Table/Chart
climMKY8F
climMKY8F
Does anybody know if there is a way within C3D for me to be able to put all the utilities together in a chart/table where it mention about the potential crossing utilities? If so, can you please share screenshot(s) of the step(s) to get to that?
Thank you!
Joe-Bouza
I use a pipe network table with a network of only crossing pipe and it spits out the utility description, size, material, inverts and station
Joe Bouza
climMKY8F
Hi @Joe-Bouza - how do you get to that step? When I try to create a table, it only gives me information about the pipes instead of the information for the crossing utilities.
Joe-Bouza
I assume you have network(s) for the utility, including everything that doesn't necessarily cross. You can either manually select the crossing pipe or split them to <crossing network>
The contents of the table is up to you. Edit a table style to have the contents you want/ need.
I know you are going to be disappointed with this next statement. you probably want a table that list thing like water over sanitary with the clear distance. this table isn't going to do that. it will only list the one pipe info as a "potential crossing". I know this is disappointing and why civil 3d doesn't do it is rather bewildering. All the necessary data is there but they don't have it.
the only way I know how to get a tabel of enumerated crossing | utilty1/ utility 2 | separation distance. is with a dynamic block.
The dynamic block can be defined with fields for number, crossing type and distance. basically a block with attributes that get info passed to them with fields. the distance field can be accomplished with  a stretch parameter.
... I'm going on about Dyno Blocks and dont know if you know much about them. do you?
Joe Bouza
v-silvestre
I don't know of a way for C3D to automatically generate a table showing utility crossing conflicts, but a way you can identify potential conflicts with pipe networks is to use the Interference Check.  You select the Pipe network (a single network or 2 specific), set the minimum distance criteria and C3D will identify any the crossings.  From there you'd have to do some manual work in plan & profile to get your crossing elevations.
https://help.autodesk.com/view/CIV3D/2024/ENU/?guid=GUID-E1D20687-9A55-463E-BD14-4178AB9BD7D7
Joe-Bouza
This tool drives me nuts. It can gather all the data for for all the crossing pipes, obviously it computes the separation, and it cant give a table.
A Utility crossing table is a fundamental requirement of civil plans. particularly when submitting to a DOH.
And the interference tool does it all just wont spit it out
Joe Bouza
