Crossing pipes not showing up in profile
Message 1 of 20
I have a pipe network and it is data referenced in into another file for labelling/plan production.  The crossing pipes are showing up in the original file but not the file they are referenced into.  I have tried everything and cant get them to show up.  The label references them but that's it.  Does anyone have any experience with this.  Thanks in advance.
Replies (19)
Message 2 of 20
Jay_B
In the Plan production drawing ( assuming they have at least been drawn in profile) ?
Profile View Properties > Pipe Networks tab > Go all the way to right to > "Style Override" column & apply your crossing style to the crossing pipes here.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 3 of 20
I have done that and nothing shows up.
Message 4 of 20
Jay_B
Are these crossing pipes connected to structures?
C3D 2018.1
C3D 2016 SP4
Message 5 of 20
Yes, I have checked to make sure the mask is turned off and it is.
Message 6 of 20
Jay_B
Ok, then it might be as simple as making sure that the ellipse pipe end you wish to see in the structure is toggled off in Pfl View Properties > PN tab.
I know this seems odd, but how I remember this behavior is, If I wish to see the pipe end display in structure in profiles, then the pipe display must be toggled off.
C3D 2018.1
C3D 2016 SP4
Message 7 of 20
I made the changes you suggested and the pipes show up now but not as ellipses.  I have included screen shots to verify that I did everything correctly.Pipe not showing as ellipse.JPGPipe not showing as ellipse PV.JPG
Message 8 of 20
civilman1957
You have to change the style of the pipe. If it's a crossing pipe, it has to have its own style. In that style, you're display in profile view should have everything turned off except "crossing pipe outside wall". That will show an ellipse where your crossing pipe crosses the main line.
Cad Manager/Senior Engineering Technician
Autodesk Certified Professional
Intel(R) Core (TM) i7-7700 CPU
3.60 GHz/24 GB BEAST
Civil 3D 2013/2014/2017/2018/2020
Message 9 of 20
Jay_B
You mentioned they look correct in the source drawing, so go look at profile view properties PN tab in that dwg & then make the Plan production match the source dwg.
Without seeing the dwg file it's hard to say what the culprit may be.
C3D 2018.1
C3D 2016 SP4
Message 10 of 20
We have a crossing style and that is what it was originally on.  I have been changing everything I could think of to make them show up so I probably hadn't changed it back.  When I check the "Show only crossing pipes" box the pipes don't show up anymore so maybe they aren't crossing but then again why are they in the original file?  They are pipes 135 and 136.4.JPG1.JPG2.JPG3.JPG
Message 11 of 20
They don't show up as a crossing pipe in the original file either but still show up in the structure.6.JPG5.JPG
Message 12 of 20
Jay_B
Try this.
In your screen shot, assuming pipe 135 is one of the crossing pipes, uncheck "draw" column, go to that structure number & edit structure style > Display tab < View Direction: Profile > Structure Pipe Outlines > on.
C3D 2018.1
C3D 2016 SP4
Message 13 of 20
That worked. Thanks
Message 14 of 20
Jay_B
You're welcome & Welcome to the Forums!
BTW - You should not need to manipulate the structure style like I mentioned if properly setup in the dwt.
If you have a dwt that has everything set up properly be sure to begin every new dwg with the dwt.
Hope that helps.
C3D 2018.1
C3D 2016 SP4
Message 15 of 20
F.Camargo
@Anonymous wrote:
That worked. Thanks
bcampbell,
Could you please attached the imagem of the result?
Because I think I have to do the same think in my profile. 🙂
Message 16 of 20
Well, it's working in some places and not in others.  I am lost again.
Message 17 of 20
Jay_B
It's most likely a combination of post 6 & post 12 listed above.
What version & Service Pack are you using?
C3D 2018.1
C3D 2016 SP4
Message 18 of 20
F.Camargo
I'm trying to do something like this, and making the pipes.
Message 19 of 20
F.Camargo
My structre is very wierd. Smiley Sad
I'd like to fix it. It is the same type of the structure and shows different.
Message 20 of 20
mitch.lawrence
This worked for me in my particular circumstance. Thanks for mentioning this requirement.
