Cross section Band Text
victor_voronkov_AVF2GTWHKP8Z
I'm having a strange issue with my cross sections when I try to add a band with level difference the text location shows up lower than it should and in some cases works fine not sure what this is.
CivilFlow
Does the text shift only happen for positive or negative differences? Hard to see from images.
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Infrastructure Design Professional
AutoCAD Design Professional
It doesn't matter if the value is positive or negative in the original screenshot all values are positive, here's another one where are all values are negative.
andrewpuller3811
Can you share the drawing?
Or share a drawing with the band style and bandset in it?
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 11
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2023
Hey Andrew, file attached I've saved the band set I'm using screenshot for reference, cheers
