Creation of DEM, georeferenced in the UK
Message 1 of 11
We have long since struggled at my company to export our civils 3d models to a .dem file tyoe, for our colleagues to use in mapinfo. The problem seems to stem from a difference in foot/metre co-ordinates however on the troubleshooting page, it states that it should work if a metre system is used. However when the UK system is selected it comes up with an error message. Can someone better explain what is happening or suggest a solution?
Replies (10)
Message 2 of 11
AllenJessup
Hello and welcome to the forum. I know that some systems just don't convert. I don't know if that's your issue. The person I think most likely to answer your questions, @Pointdump isn't around today. He'll probably be back tomorrow.
In the meantime. If you will tell us about which version of the program you're running and exactly what you've tried so far. It will assist those who may be able to help.
@Murph_Map might also be able to help but he's around less frequently. The "@" mention will notify those users I've mentioned them in this post.
If you're on Subscription and have access to the Subscription center. You could also start a support request with Autodesk
Allen Jessup
CAD Manager - Designer
Message 3 of 11
Pointdump
SR,
Welcome to the Autodesk Forums!
As Allen suggested, please tell us which version and service pack you're using, and what steps you took to export to DEM. Can you post a screen shot of that error message? Also, posting a problem drawing would help to diagnose.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 4 of 11
autoMick
A bit more specific information on your actual issue would help. I use MapInfo and Civil3d regularly so might be able to help. Posting the file(s) and any metdata is the key.
Cheers
- Mick
Civil3d user in Australia since 2012.
Message 5 of 11
Thanks all. Running Civils 3d 2016 with service pack two. I have uploaded the drawing in question, however the problem doesnt seem to be drawing specific as it is related to the drawings co-ordinate system, of which all of ours are the same.
I select the surface in the toolspace and select 'Export to DEM...'
The first picture is the error, the second is a list of alternative co-ordinate systems I could use. This is only populated with USA and a few other countries - nothing related to the UK.
Message 6 of 11
Pointdump
SR,
Confirmed. I'm getting same.
I haven't had much luck exporting to DEM. Export to GeoTIFF instead. What file format do you need for MapInfo? You might need to do a two-step and convert the GeoTIFF to whatever format you need.
Dave
Dave Stoll
Las Vegas, Nevada
Message 7 of 11
We need a .dem or .asc for use in map info as the guys read off level data etc from it. Therefore I think geotiff is unsuitable, after speaking to collegues? Can anyone advise on if you can export to.asc?
Message 8 of 11
Pointdump
SR,
There's a couple of methods by @autoMick and @Alfred.NESWADBA in <<<This Thread>>>.
Dave
Dave Stoll
Las Vegas, Nevada
Message 9 of 11
Pointdump
SR,
And Microdem will convert a GeoTIFF to a DEM or ASC or XYZ:
Dave
Dave Stoll
Las Vegas, Nevada
Message 10 of 11
Thanks alot - I will try converting to cogo points and then into .asc and see how that goes!
Message 11 of 11
antoniovinci
Sir, please give my attachment to your Mapinfo collegues: is it what you're after?
