Creating Surface from GEOTIFF DEM
Can someone give me a simple work through on combining a GeoTIFF file and a DXF file into one file on Autodesk?
Thanks for your help
tmachado
Hi @Anonymous, welcome to the Autodesk forums!
what is in your DFX file?
Hope this will help!
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the LIKES button
Tatiana Machado
BIM Manager/ Autodesk Certified Instructor
Blog | Twitter | LinkedIn
InfraWorks Ambassador
tmachado
To import a DEM or GeoTIFF surface in Civil 3D:
  1. In the Prospector, right-click on Surfaces and select Create Surface from DEM…
  2. Browse and select the surface to import. You have the choice of importing... DEM, GeoTIFF, ESRI ASCII GRID (.asc), ESRI ASCII GRID (.txt), ESRI BINARY GRID (.adf).
Tatiana Machado
tcorey
Assuming your dxf is linework representing breaklines:
Create a TIN Surface. Do not Create Surface from DEM as this will disallow adding of breaklines.
Add the .TIF to this surface as a data source.
Insert the dxf after having made it into a dwg.
Add those objects as breaklines.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
