Point cloud not displaying as an xref
I have a file which I have xref'd a cloud surface. For the life of me I can not get the contours to display in the second file. I have "LEVELOFDETAILL OFF"  in both files and all the layers are on in both files.  I have "zoomed extents" and did a "regenall". Nothing is showing up. According to the Autocad help files I should be able to reference a point cloud to a second file....or do they lie.
Vrs 2015 in use.
Dave Z.
tcorey
Try using data reference (Create Data Shortcut), not xreference.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Ok I finally got it. If I make sure "LEVELOFDETAIL" is off in both files before I try and xref it appears to work.
I will keep in mind the data reference in case it acts up.
