hi there , i have a problem that each time i try to make section sheets through civil that after i make the section view group and set the sections as i want in the print area , when i make the sheets itself , i always see the viewport in sheets shows different place than the print area in model which i put the sections in , is there a solution for this ??
like this in the 2 photos , in model it is ok but in the layout they are out of the area
Solved by cwr-pae. Go to Solution.
Looks like the plot scale in model space and the viewport are different, either set the model space scale to match the view port or regenerate each sheet after switching layouts. I find its best to keep the model space scale set to my view port scale with section views.
Or you tried to manually position the section views, c3d insists on placing the views itself based on the parameters you set in the section, sheet and group plot styles. If you move them C3D will not handle them properly until you update the section view layout.
