which option should I use to draw horizontal curve where the point of intersection occurs
Thanks.
Thanks.
Edit the Alignment geometry...from the toolbar select the dropdown for the "Add Curve" (looks like an arc with three dots) and pick the curve you want. Probably the "Free Curve Fillet" and then select the first straight segment, then the second, then enter the radius distance.
This is additional to the jroot's comments.
I think you have two PI that need horizontal curves.
So you have to be careful over the length of each curve.
The best option here would be free curve fillet with through point. If radius need to adjusted you can do it through parameter editor.
Also you can use free curve fillet with radius option also.
