Creating Reports In Word & Excel
I'm trying to create in Word and Excel but they are not working?
Replies (18)
rl_jackson
Could you explain whats not working and version of C3D your using. Are you getting a error? Usually the report is a html file that gets copied to word or excel
Rick Jackson
Survey CAD Technician VI
This may be pr-mature but i downloaded the 2019 C3D. It does create a .html but not a Word or Excel document.
rl_jackson
Yes it has always created reports in that manner, then you just select the text and copy & paste to the desired office software.
Rick Jackson
Jay_B
Depending on the report created, there may be an option to specify report output file type on the "Save As" dialog.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
tmachado
hI @Anonymous, Which report are you having issues with?
I am able to save reports as Word and Excel in C3D 2019
Hope this will help!
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the LIKES button
Tatiana Machado
BIM Manager/ Autodesk Certified Instructor
Blog | Twitter | LinkedIn
InfraWorks Ambassador
Jeew-m
Dear Friend,
This video might be helpful to you.
Further if you can select All (Ctrl+A) the contents of the html file, copy it and paste it on excel or word.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
C3D 2016, C3D 2019
I usually cut and paste but i don't want to half to do it that way.
Jay_B
Have you tried changing the output file type at the bottom of the report Saveas dialog box?
Also can you please let us know which Report you're having trouble with?
C3D 2018.1
C3D 2016 SP4
copper.chadwick
Autodesk Support
Autodesk Support
@Anonymous,
Hi there! This is a great opportunity to meet you, My name is Copper Chadwick, and I would like to help you with trying to export and create reports in Word & Excel formats. I am however a bit confused on a couple of points that you might be able to clear up for me with answering a few of my questions.
  • What software specifically are you working in when creating these reports?
  • What kind of reports are you trying to create?
  • What kind of objects or to what purpose are you creating reports?
  • What is your preferred format to create those reports, (how would you like it to work, ideally)?
Thanks in advance and I hope we can get this issue resolved quickly for you.
Copper Chadwick
Designated Support Specialist
copper.chadwick
Autodesk Support
Autodesk Support
@Anonymous,
I am checking back to see if my post helped you with your problem or question. Please mark my post as the solution if it resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved. Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
Copper Chadwick
I can create an excel but on a Word Doc.
  • What software specifically are you working in when creating these reports? 2018 C3D
  • What kind of reports are you trying to create? Word Document Excel Works in 2018.
  • What kind of objects or to what purpose are you creating reports? Parcel Mapcheck
  • What is your preferred format to create those reports, (how would you like it to work, ideally)? In Word
This is what happens. I try to create a report in word but it stalls.
Auto Desk 2018 Civil 3D 64bit Windows 10
tmachado
I have no problems,  saving this report as a word doc in C3D 2018 or C3D 2019
Tatiana Machado
copper.chadwick
Autodesk Support
Autodesk Support
@Anonymous,
That is unfortunate, I am having difficulties duplicating your problem, within civil 3D 2018 or Civil 3D 2019. I do have another question to ask (they may seem too simple, but just to eliminate all potential errors in the process):
  • In your sceenshot you shared (thank you by the way, that really helps); it shows that you are trying to save the report file to a location "A:\Civilre...doc" - Is that a folder location you have permissions and access to normally? Try to change the save as location to a more safe location such as "C:\ Users\<your username>\Documents\Civilre...DOC"
I am attaching a screenshot of, maybe, a more conducive file save location?mapcheckreport.PNG
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.​
Copper Chadwick
Solved:
I found the answer here.
https://support.office.com/en-us/article/enable-or-disable-confirm-file-format-conversion-on-open-2b...
Enable or disable confirm file format conversion on open
Word offers you the option of having a file format conversion dialog box appear when you open a document in a non-Word format such as plain text, RTF, or HTML file.
  • If the check box is selected, Word informs you that it's doing a conversion and gives you the chance to select a different file converter, if you want to.
  • If the check box is cleared, Word does the conversion automatically.
If you no longer want this dialog to appear, you can disable it in Word options.
  1. Open the Word Options dialog.
    • In Word 2007, choose Microsoft Office Button Click the Microsoft Office Button and choose Word Options.
    • In Word 2010 or later, select File > Options.
  2. In the left pane, select Advanced, and scroll down to the General category.
  3. Clear the Confirm file format conversion on open check box.
  4. Click OK to save your changes.
copper.chadwick
Autodesk Support
Autodesk Support
@Anonymous,
Great news I'm glad you were able to solve that!
Copper Chadwick
