Creating points on an alignment using a profile
thendryx
thendryx
I set points on an alignment utilizing the finished grade profile.  I'm surprised to find the point elevations are not dynamic and change if the profile is manipulated.  Is it possible I'm not doing it correctly?
TLH
rl_jackson
I don't believe there's anything native to C3D to do what you what but Pt2Profile (quuxsoft.com) in Sincpac may help or @Jeff_M may have another suggestion.
Rick Jackson
Survey CAD Technician VI
brian.strandberg
I don't believe any cogo points operations are dynamic to another object, correct me if I'm wrong.  I tried creating cogo points from corridor and using the crown point.  Same issue, when the corridor changes the points just stay the same.
This would be nice to have for people creating staking drawings.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
Jeff_M
Using the DynamicLinking of points in the Sincpac will help with this.
Jeew-m
With the current settings in Civil 3D the easiest way to achieve your task is settings the elevations on points using a surface. So my suggestion is as follows.
Put all your points (created from profile) in a point group
Create a dummy corridor and a corridor surface using the alignment and profile.
Make the corridor rebuilt automatic
When you do any changes to the profile;
Right click on point group --> Select (To select all the points inside group)
Right click again -->Elevations from surface --> Select the corridor surface
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
