creating ifc for civil/ infraworks
sandor70
sandor70
I'm writing the ifc for import in civil/ infraworks, the file is correctly imported, but is not in the properly coordinate system.
How can i specify the coordinate in IFC, usable for infraworks?
Thanks in advance
Alessandro Casadei
Setec informatica
VincentSheehan
Did you export data from Civil 3D? If so, make sure the coordinate system is set in Civil 3D. Also make sure the coordinate system is set when you import the IFC file into Infraworks.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
heather_tracy
Hello, @sandor70,
Did the information provided by @VincentSheehan help you and answer your question?
If yes, please click on the "Accept Solution" button on the post(s) that solved your problem. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
Heather | Community Manager
