Creating a surface Data Shortcut
RalphBrown99
RalphBrown99
Hi:
I have a surface in my drawing that was created by reference from Data Shortcut option in the Toolspace. Now I am trying to create a Data Shortcut using this surface -I do not know if it is possible-.
I do right click in Data Shortcuts and select Create Data Shortcuts I ended in a window where my surface is not available.
If it is not possible to create a Data Shortcut with this surface, how is possible to find the original Surface-Data Shortcut so I can make it available for other drawings -which is what I need-
To make your life easier, I am sending a .png file so you have a better idea what the problem is.
RM
Accepted solutions (3)
tcorey
Promote the surface and then you can create the data shortcut.
To Promote a surface, right click on the surface name in Prospector. You will see Promote as an option.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
KirkWM
If you are trying to track down the original source, in C3D 2016 there is a new "Manage Data Shortcuts" tool. Go to MANAGE tab -> DATA SHORTCUTS panel -> MANAGE DATA SHORTCUTS. The window that opens shows data shortcuts in your current drawing. Click on data shortcut in question, then look below for PATH and SOURCE FILE name. What might be even tricker is finding the original working folder and project folders which point to all the data shortcuts in the project. GL!
Hidden_Brain
If you highlight the Surface heading under toolspace, the grid view at the bottom of the toolspace lists the paths to all the source files for the data shortcut surfaces. see attached.
RalphBrown99
HI Corey, sorry for the long replay. Thanks for the solution, I promoted the surface and now I can create a Datashorcut from it
Rafael
RalphBrown99
Hi Kirk, sorry about the long replay. Your post was super helpful
RalphBrown99
Thanks for your help, sorry for long replay
