The Incredible Shrinking Command Bar
I have had this issue since I began using civil 3d, but it appears to have been an issue forever. Every time I click on the New Tab button, to get to the Start Drawing Templates (which I have spent alot of time setting up correctly) and switch back to an open dwg or close the new tab, my command bar shrinks. It has done this ever since day 1, as far as I can remember, and its annoying to have to unlock the ui, resize/reposition the bar, and re-lock the ui every time I make a new file.
Others have posted similar problems, but none have dealt with New Tab and the fact that it cleans the screen every time it is activated. I happen to have half of my toolbars on my other screen, so the screencast does not show the whole picture. Even switching between an open dwg and New Tab cleans the screen. I find using New Tab and create from template to be more convenient than navigating to my template file and opening it every time I need to start a new dwg.
My workspace setting is set to Automatically save changes, so this is irritating as heck. The help file only lists 5 options for LockUI, but I found
LockUI 15 on another post, and it almost does all the locking I could ask for.
Is there anything I may have overlooked? Some hidden workspace option perhaps? I used the default Civil 3d ws and modified it to suit.
Apologies if this rant is in the wrong place.
