how do I go about creating a block that once exploded one can obtain the layering name, color etc.
Than you.
Solved by MMcCall402. Go to Solution.
Do you mean you want that information for each of the entities that was part of the block before exploding? Explode the block and check Properties of the resultant entities.
A block can be created on any layer and that information stays with the block. So I'm unclear what your looking for.
Rick Jackson
Survey CAD Technician VI
If the objects comprising the block are created on Layer 0 the block inherits the properties of the layer it is inserted on OR the if the objects are on specific layers these will be retained on insertion of the block
neilyj (No connection with Autodesk other than using the products in the real world)
Let's say I have a grading plan with 20/30 layers. I like to make a block of those layers so it can be downloaded/ forwarded to another user that once exploded they will have those layer arranged on their drawing instead of creating a LAS.
